wangdynasty
SD Boot Problems with FSBL in Vivado2016.4
Hi everyone, I am transfering projects from ISE14.7 to Vivado2016.4. With ISE FSBL project, my board can boot successfully and linux run normally, but when using Vivado FSBL project, my board can not boot. Then I debug the FSBL codes, and found that it stopped at a function called f_open(), which should return XST_SUCCESS but my function returns FR_NOT_READY, here is the snapshot.
wangdynasty
Here is my board and the TF Card.
The ISE project and Vivado project are all the same PS setting and blank PL logic, why the differenct result? Which change cause the problem?
BTW, I have tried Vivado 2017.1, also cause the same problem.
han_2012
Hi, I also encountered this problem. So, how did you solve this trouble?
Thank you!
