Visitor jules_b
SDK 14.4 : " UNABLE to STOP MicroBlaze " / " Could not detect
I am currently working on a Digilent board (ATLYS) with a Spartan-6 XC6SLX45 fpga using SDK v14.4, and I am encountering a strange problem:
When I click on "program FPGA" everything runs smooth, but when I try to launch debug, I get one of those two error messages (about 50% chance to get one or the other):
I looked upon the forum for similar problems and find many post describing one problem or the other, but not both simultaneously, and the solutions I found were either not applicable or did not seem to work on this specific problem.
Here is the content of my mhs file if that may help:
# Created by Base System Builder Wizard for Xilinx EDK 14.4 Build EDK_P.49d
# Tue Jun 16 09:22:09 2015
# Target Board:  Custom
# Family:    spartan6
# Device:    xc6slx45
# Package:   fgg676
# Speed Grade:  -2
 PARAMETER VERSION = 2.1.0
 PORT RESET = RESET, DIR = I, SIGIS = RST, RST_POLARITY = 0
 PORT CLK_P = CLK, DIR = I, DIFFERENTIAL_POLARITY = P, SIGIS = CLK, CLK_FREQ = 100000000
 PORT CLK_N = CLK, DIR = I, DIFFERENTIAL_POLARITY = N, SIGIS = CLK, CLK_FREQ = 100000000
BEGIN proc_sys_reset
 PARAMETER INSTANCE = proc_sys_reset_0
 PARAMETER HW_VER = 3.00.a
 PARAMETER C_EXT_RESET_HIGH = 0
 PORT MB_Debug_Sys_Rst = proc_sys_reset_0_MB_Debug_Sys_Rst
 PORT Dcm_locked = proc_sys_reset_0_Dcm_locked
 PORT MB_Reset = proc_sys_reset_0_MB_Reset
 PORT Slowest_sync_clk = clk_100_0000MHz
 PORT Interconnect_aresetn = proc_sys_reset_0_Interconnect_aresetn
 PORT Ext_Reset_In = RESET
 PORT BUS_STRUCT_RESET = proc_sys_reset_0_BUS_STRUCT_RESET
END
BEGIN lmb_v10
 PARAMETER INSTANCE = microblaze_0_ilmb
 PARAMETER HW_VER = 2.00.b
 PORT SYS_RST = proc_sys_reset_0_BUS_STRUCT_RESET
 PORT LMB_CLK = clk_100_0000MHz
END
BEGIN lmb_bram_if_cntlr
 PARAMETER INSTANCE = microblaze_0_i_bram_ctrl
 PARAMETER HW_VER = 3.10.c
 PARAMETER C_BASEADDR = 0x00000000
 PARAMETER C_HIGHADDR = 0x0000ffff
 BUS_INTERFACE SLMB = microblaze_0_ilmb
 BUS_INTERFACE BRAM_PORT = microblaze_0_i_bram_ctrl_2_microblaze_0_bram_block
END
BEGIN lmb_v10
 PARAMETER INSTANCE = microblaze_0_dlmb
END
 PARAMETER INSTANCE = microblaze_0_d_bram_ctrl
 BUS_INTERFACE SLMB = microblaze_0_dlmb
 BUS_INTERFACE BRAM_PORT = microblaze_0_d_bram_ctrl_2_microblaze_0_bram_block
END
BEGIN bram_block
 PARAMETER INSTANCE = microblaze_0_bram_block
 PARAMETER HW_VER = 1.00.a
 BUS_INTERFACE PORTA = microblaze_0_i_bram_ctrl_2_microblaze_0_bram_block
 BUS_INTERFACE PORTB = microblaze_0_d_bram_ctrl_2_microblaze_0_bram_block
END
BEGIN microblaze
 PARAMETER HW_VER = 8.40.b
 PARAMETER C_INTERCONNECT = 2
 PARAMETER C_USE_BARREL = 1
 PARAMETER C_USE_FPU = 0
 PARAMETER C_DEBUG_ENABLED = 1
 PARAMETER C_ICACHE_BASEADDR = 0X00000000
 PARAMETER C_ICACHE_HIGHADDR = 0X3FFFFFFF
 PARAMETER C_USE_ICACHE = 0
 PARAMETER C_ICACHE_ALWAYS_USED = 0
 PARAMETER C_DCACHE_BASEADDR = 0X00000000
 PARAMETER C_DCACHE_HIGHADDR = 0X3FFFFFFF
 PARAMETER C_USE_DCACHE = 0
 PARAMETER C_DCACHE_ALWAYS_USED = 0
 BUS_INTERFACE ILMB = microblaze_0_ilmb
 BUS_INTERFACE DLMB = microblaze_0_dlmb
 BUS_INTERFACE M_AXI_DP = axi4lite_0
 BUS_INTERFACE DEBUG = microblaze_0_debug
 BUS_INTERFACE M_AXI_IP = axi4lite_0
 PORT MB_RESET = proc_sys_reset_0_MB_Reset
 PORT CLK = clk_100_0000MHz
END
BEGIN mdm
 PARAMETER INSTANCE = debug_module
 PARAMETER HW_VER = 2.10.a
 PARAMETER C_USE_UART = 1
 PARAMETER C_BASEADDR = 0x41400000
 PARAMETER C_HIGHADDR = 0x4140ffff
 BUS_INTERFACE S_AXI = axi4lite_0
 BUS_INTERFACE MBDEBUG_0 = microblaze_0_debug
 PORT Debug_SYS_Rst = proc_sys_reset_0_MB_Debug_Sys_Rst
 PORT S_AXI_ACLK = clk_100_0000MHz
END
BEGIN clock_generator
 PARAMETER INSTANCE = clock_generator_0
 PARAMETER HW_VER = 4.03.a
 PARAMETER C_CLKIN_FREQ = 100000000
 PARAMETER C_CLKOUT0_FREQ = 100000000
 PARAMETER C_CLKOUT0_GROUP = NONE
 PARAMETER C_CLKOUT0_BUF = TRUE
 PARAMETER C_CLKOUT0_DUTY_CYCLE = 0.500000
 PARAMETER C_CLKOUT0_PHASE = 0
 PORT LOCKED = proc_sys_reset_0_Dcm_locked
 PORT CLKOUT0 = clk_100_0000MHz
 PORT RST = RESET
 PORT CLKIN = CLK
END
BEGIN axi_interconnect
 PARAMETER INSTANCE = axi4lite_0
 PARAMETER HW_VER = 1.06.a
 PARAMETER C_INTERCONNECT_CONNECTIVITY_MODE = 0
 PORT interconnect_aclk = clk_100_0000MHz
 PORT INTERCONNECT_ARESETN = proc_sys_reset_0_Interconnect_aresetn
END
BEGIN axi_timer
 PARAMETER INSTANCE = axi_timer_0
 PARAMETER HW_VER = 1.03.a
 PARAMETER C_ONE_TIMER_ONLY = 1
 PARAMETER C_BASEADDR = 0x41c00000
 PARAMETER C_HIGHADDR = 0x41c0ffff
END
If anyone got any idea about this, I'm all hears !
Best regards,
Jules
Re: SDK 14.4 : " UNABLE to STOP MicroBlaze " / " Could not detect
@jules_b
Looks like Microblaze is in the reset state.
The reset polarity for the board you are working seems  active high.
So i would suggest modifying the reset polarity to 1.
Hope this helps.
Achutha
The board that you are referring to seems to have a single ended clock. Refer to the MHS that is available at this location.
The MHS that you copied seems to have a differential clock. Do refer to one of the EDK examples(Atlys_AC97_EDK_demo as an example) and compare the MHS/UCF of your design.
http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,836&Prod=ATLYS
--hem
