Visitor yakov.erlich
SDK 14.7 fails to open after windows update.
Hi, I use SDK Release 14.7 Build SDK_P.20131013 on Windows 10 Pro, 64 bit.
It worked fine from beginning, during several month,  until last windows update:
[https://support.microsoft.com/en-hk/help/4345421
July 16, 2018—KB4345421 (OS Build 17134.167)Applies to: Windows 10, version 1803].
After the update, when I lunch the SDK from a desktop icon, a cmd windows appears on half of second, but SDK does not start.
So, to continue my work I currently uninstall this windows update. But the update goes back automatically each weak.
Tags (4)
Re: SDK 14.7 fails to open after windows update.
Hi @yakov.erlich
try delete the folder .metadata in your project sdk folder (example \MicroblazeProjectFolder.sdk\.metadata)
And start again the SDK, if it work you will need to add again your project with File -> Open projects from file system...
Hope it works for you, I've to do that procedure about every hour
After some thinking regarding your advice, I have doubt that it can help.
In my situation, the Workspace launcher (having Select a workspace browser) does not appear, only Cmd window flashes on half on second, no more. This means that usage .metadata is not reached! So the .metadata does not impact and is not  a reason of the problem.
I add some more info regarding this problem
 After my PC has restarted the "bad" Windows update came back again and I did some tests.
1. As
2.I opened Cmd windows and run the SDK from CMD as below (note, in state before the problem appears, I run this Cmd operation and SDK has been started). My purpose was to see any error message that will help to identify a reason of the problem. As a result SDK does not started and no any message appear.
D:\>cd Xilinx\14.7\ISE_DS\EDK\bin\nt64
D:\Xilinx\14.7\ISE_DS\EDK\bin\nt64>xsdk -vmargs -Dorg.eclipse.swt.internal.gtk.cairoGraphics="false"
Hi @yakov.rlich
You are right on your statement that if workspace is not open metadata folder should not have any effect at all.
Definitivelly seems to be some kind of issue with Eclipse or Java underneeth... Can you try to to launch SDK without adding the the extra parameters?
Ibai
Ibai
Visitor derekyu
I have similar problem in SDK 13.4. Here is the windows event log:
Faulting application name: xsdkw.exe, version: 0.0.0.0, time stamp: 0x4efc4cff
Faulting module name: ucrtbase.dll, version: 10.0.17134.165, time stamp: 0xfdc3d6f1
Exception code: 0xc0000005
Fault offset: 0x0000000000019948
Faulting process id: 0x1e24
Faulting application start time: 0x01d42f29fa612053
Faulting application path: C:\Xilinx\13.4\SDK\SDK\bin\nt64\xsdkw.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: e959ae25-ad77-4e38-ac5c-25826ebf5c7b
Faulting package full name:
Faulting package-relative application ID:
I reported the problem to Microsoft but no respond yet.
