SDK 14.7 failure in flash programming
Hi all,
I am unable to use SDK 14.7 to program binary file into flash of microBlaze. I keep geting the error : "CFI query of block/sector map returned inconsistent result!".
I see in other thread that other also got this failure with 14.7, while 14.4 works. should I try 14.4 ? Can I install it in the same computer ? Is it suffecient to donwload just the SDK or just the "lab tools" instead of the full package ?
Ran
Re: SDK 14.7 failure in flash programming
You can install 14.4 in the same machine.
IF you want to install just lab tools, select ISE labtools in one of the installations screens (i.e., select Products to Install)
Vinay
Scholar sampatd
We found some issues with the "-Os" optimization flag in the GCC compiler that was used to build the Flashwriter drivers for 14.7 version of the tool.
The workaround for the issue is replacing -Os with -O3 in the GCC command in flashwriter.tcl file @ C:\Xilinx\14.7\ISE_DS\EDK\data\xmd
It works for Virtex-6 LX240 board.
Thanks a lot.
@the workaround for the issue is replacing -Os with -O3 in the GCC command in flashwriter.tcl file @ C:\Xilinx\14.7\ISE_DS\EDK\data\xmd
Visitor andrescc
It also works for Virtex-5 LX110T.
Just be sure also to replace the lines:
set EXTRA_COMPILER_FLAGS  -O3
set gcc_cmd "powerpc-eabi-gcc -O3 $mcpu ...
Thanks!
Scholar sampatd
Please mark the above post as "Accept as solution" if it has resolved your issue so that we can close this thread.
Thank you,
I haven't tried that yet (been working with 14.4 all that time), but I will mark it as a solution and try it in the first opportunity.
Thank you!
Ran
