SDK 2014.1: Cannot download to target, "Another launch session with the same debug configuration is currently in progress."
Here's one of many problems I never saw until I updated to Vivado 2014.1. I'm using a Zynq part, and in SDK I can program the FPGA with a bitstream, but when I try to download the elf file onto the ARM, I'm given the error
"Another launch session with the same debug configuration is currently in progress. Please wait until the previous launch is complete and then try again."
In XMD, disconnecting and connecting, and resetting don't change this problem. Similarly, when I try to download the .elf file directly through XMD it fails and says
Unknown Error Occured
Section, 0x00100000-0x0010f88b Not Accessible from Processor I-Side Interface
This is absurd, I used to be able to just download elf files without even involving XMD, so I'd love to know what's going on here.
Re: SDK 2014.1: Cannot download to target, "Another launch session with the same debug configuration is currently in progress."
It seems I've found a solution, simply "rst -debug_sys" in the XMD console. I think it used to do that automatically, but now if you have multiple SDKs open you need to manually release the one that's debugging.
Do you see this issue for the pre-defined zc702/zc706/zedboard hardware in SDK?
Is this only see for your workspace?
Will you be able to share the workspace?
Achutha
Is there a solution for this now? I also have this problem since 2014.1
