SDK 2014.4 crashes
Hi all!
I am following this tutorial in order to set-up my new ZedBoard with Ubuntu 16.04 and Vivado 14.4. When I create a new application based in Hello World, I select Run As -> Launch on Hardware (GDB). After a few seconds, SDK crashes without print 'Hello World' in the terminal console.
I get this message:
(Xilinx SDK:1757): IBUS-WARNING **: The owner of /home/cristina/.config/ibus/bus is not root!
Experimental:  JNI_OnLoad called.
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007ff1a546a24d, pid=1757, tid=140675835631360
# JRE version: Java(TM) SE Runtime Environment (8.0_05-b13) (build 1.8.0_05-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.5-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C  [librxtxSerial.so+0x724d]  read_byte_array+0x3d
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/cristina/hs_err_pid1757.log
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Before launching the program I deleted .config/ibus.
Log error file:
Any help would be appreciated!
Thx!
Re: SDK 2014.4 crashes
Hi @cluna.aistechspace,
No sure what is going wrong but seems that might be related to the Terminal feature within the SDK. Did you try to debug the application without using the integrated terminal? (use TeraTerm, Kitty or so for checking the serial output).
BTW, is there any particular reason of using such an old tool? Xilinx is already in 2018.2 release and there have been quite a lot of improvements in the way.
Ibai
Ibai
I'm following the ZedBoard tutorial. I'm using this version of Xilinx because it's the one licensed with the ZedBoard.
I'm new using that board and I'm doing what I can. SDK 14.4 crashes many times for different reasons and I'm going nuts :(
Using CuteCom instead SDK's terminal works! But I'm still thinking that SDK's terminal should work too
So that confirms that the issue is in the Terminal feature of the Eclipse environemnt. There is no any known issue in 2014.4 release notes that points to this feature be broken but might be related somehow to your host machine as well. As pointed previously this SDK release so I would either recommend to use external terminal or update the SDK.
Ibai
Ibai
