SDK 2014.4 sees errors, while compiler completes without any error
quite for a while I have a pretty annoying bug in the SDK2014.4.
I started to develop some new parts in the project in C++ a few months ago and it worked quite well.
But now I'm facing more and more some strange errors displayed in the SDK.
While the compiler completes without any errors (see console tab in pic) the SDK parser shows some errors in some files.
In fact it shows a function is ambiguous error. I had this error before in a class where multiple functions with same names but different arguments have been, but I could get rid of them.
- Now in this case there is no other function with the same name so why could it be ambiguous?
- Or at least how can I avoid those "ghost errors" within the SDK?
Code:
class CANcontroller {
    public:
         typedef enum {
        } Status;
        virtual StdError setControllerStatus(CANcontroller::Status st) = 0;
class canMCP2515 : public CANbus::CANcontroller {
public:
typedef enum {
    } statusMCP2515; // has same names and values like CANcontroller::Status
     virtual StdError setControllerStatus(CANcontroller::Status st);
debrajr
You can always delete the .metadata folder in SDK workspace on your Windows drive. Let the project re-build and see if it helps you.
Debraj
