SDK 2016.2 getting stuck in "Initializing s/w repositories" stage
I am running Windows 10 (latest update). I have Vivado & SDK 2016.2 installed. Upon building a project in Vivado, exporting the hardware & launching SDK through Vivado, the SDK windows opens but is getting stuck in "Initializing s/w repositories" phase. It took 1hr to do this & the SDK log showed following
15:06:14 INFO    : Launching XSDB server: xsdb.bat -interactive E:\hdl_dev_adc_dac_MEO_Booster_v00\projects\fmcomms5\zc706\fmcomms5_zc706.sdk\temp_xsdb_launch_script.tcl
15:06:16 INFO    : XSDB server has started successfully.
15:06:16 INFO    : Restoring global repository preferences:
         C:\Xilinx
16:06:38 ERROR    : (XSDB Server)ERROR: [Hsi 55-1433] Error boost::filesystem::status: Access is denied: "C:/Xilinx\SDK\2016.2\gnu\microblaze\linux_toolchain\nt64_be\microblaze-xilinx-linux-gnu\lib32"
16:06:38 ERROR    : (XSDB Server)ERROR: [Hsi 55-1433] Error boost::filesystem::status: Access is denied: "C:/Xilinx\SDK\2016.2\gnu\microblaze\linux_toolchain\nt64_le\microblazeel-xilinx-linux-gnu\lib32"
16:06:38 ERROR    : (XSDB Server)ERROR: [Hsi 55-1433] Error boost::filesystem::status: Access is denied: "C:/Xilinx\SDK\2016.2\gnu\microblaze\linux_toolchain\nt_le\microblazeel-xilinx-linux-gnu\lib32"
16:07:21 ERROR    : Internal error. Unable to add C:\Xilinx as a repository.
16:07:21 INFO    : Processing command line option -hwspec E:/hdl_dev_adc_dac_MEO_Booster_v00/projects/fmcomms5/zc706/fmcomms5_zc706.sdk/system_top.hdf.
So, two questions, why is initialization taking so long & what is the above error I received?
Re: SDK 2016.2 getting stuck in "Initializing s/w repositories" stage
I tried the proxy settings you suggested but it didn't affect anything. Initializing s/w repositories was still taking forever. So, once I it was over & s/w repositories were finally initialized, I removed C:\Xilinx from Global repositories. Now, SDK doesn't get stuck every time I launch it. That temporary solution is OK for me as of now
HI @kharobangdo,
It seems that SDK does not have the right to access the installation folders. Could you check if you can read or write files into these folders?
Florent
Yes, I can read & write files in C:\Xilinx\SDK directory. So what seems to be the problem
Hi @kharobangdo,
Can you try to run SDK as administrator?
Florent
The account on my PC is itself an Administrator account. So launching SDK through Vivado would be equivalent to launching it as an administrator no?
Hi @kharobangdo,
No sure how windows is working so I would try directly lauching SDK as admin.
Could you also check the proxy settings in SDK. Try to set it to direct. It has helped to solve some weird issues
Florent
