SDK 2017.2 and IAR integration
Hi everyone,
I'm currently trying to integrate the IAR compiler inside the Xilinx SDK with FreeRtos and I'm struggling to make it work.
I've got my own hardware configuration that helps me to generate a BSP. I managed to modify the MakeFiles to use the "iccarm" compiler (IAR). But when I try to compile this BSP, and especially the "standalone" part necessary for FreeRtos, I've got several errors from the specific assembly code (asm_vectors.s, boot.s, etc.).
Is there a specific assembly configuration for IAR that I can found inside the SDK installation ? Or is it a BSP configuration parameter / file that I missed ?
Alexis
Tags (3)
Re: SDK 2017.2 and IAR integration
Hello @alexis_mediane
The IAR assembler is not compatible with the GNU assembler.
The instructions are but the macros, conditionals, section declarations, etc syntax is different.
I am afraid you'll have to manually edit the .s files.
You'll likely also have to re-write the start-up code because the IAR library initialization different from Newlib's initialization used in SDK.
Eric
Thanks Eric,
I managed to find some *.S files that compile with the IAR assembler. Now I have to do the same thing for the "portASM.s" file within Xilinx-FreeRtos sources. By any chance, if someone has the translatation from GCC to IAR it'll be very helpfull.
Alexis
