jrp
SDK 2017.3 compile loops forever
Started a build of project with subject SDK.
The build just runs in a loop forever... well, so far anyway.
I have a build failure so I tried to capture build failure by pressing "Copy log file" push button.
That opens up a dialog that does absolutely nothing but drill down into the file system. No option to do anything?
What up with all that Xilinx?
arpansur
Hi @jrp,
Is it happening for the pre-defined platform also or it is specific to projects?
Arpan
jrp
Yep... not sure what a "pre-defined platform" is exactly. Can you be a little more specific please?
ibaie
Hi @jrp,
Is your issue still there? I'm wondering if you still need help with this.
Ibai
jrp
No. I suspect that it is a Eclipse thingy.
In retrospect, I wondered if the fact that I happen to be in the menu's where one turns on,
or off, the auto compile capability. This happened right after making some adjustments there.
Perhaps Eclipse (known for this?) just tied itself in a knot and couldn't find its way out.
Java tools and Java programmers crack me up man!
Thanks for asking.
ibaie
Glad to see it's not at least a blocking issue for you :)
Just mark your post as solution as that will help us to track better open issues ;)
Ibai
