Visitor prathamesh
SDK 2017.4 Windows 10 issue
Hello All,
I have been facing weird issue with simple hello world app. Looks like something is wrong with SDK2017.4 and windows 10.
I did not have any problem using my hardware design with windows 7.
from the SDK console:
"Compiling standalone"
cc1.exe: fatal error: can't open 'C:\Users\prath\AppData\Local\Temp\cc4CAvrH.s' for writing: Permission denied
compilation terminated.
I have checked known issues AR and forum but did not find anything yet.
Pratham
Visitor prathamesh
Re: SDK 2017.4 Windows 10 issue
@gwendal.hays I changed the temp directory to C:\Temp and It resolved my SDK issue.
Visitor gwendal.hays
Same issue here, only the name of the file changes.
It worked after trying several times, for no reason, but that's definitely not a solution to try again and again.
I changed the temp directory, made sure I hade all permissions, nothing changed.
Please find the log file, maybe it can help ?
Does not seem to me like a Xilinx problem but a Windows one.
AppData folder is a hidden one, and maybe the access is restricted, check that.
I also have SDK 2017.4 on Windows 10 and no problems, at least of that type. Is that happening with any project?
I agree that it is probably a Windows issue.
In my case, it happens for every project. I tried playing with the accesses, changing the temp directory, nothing changes.
Observer yfuji38
McAfee VirusScan might open the files  at the same time.
If you are using McAfee, disable and try out.
Just FYI, similar issue:
https://kc.mcafee.com/corporate/index?page=content&id=KB86515
--fuji
Visitor prathamesh
Disabling McAfee live scan mode worked for me. Also, greatly speeded up the compilation time.
Newbie jems-ford
Windows 10 is the latest operating system. It is basically using the laptop and computer. You can use the SDK in normally using in the JAVA or Android. But sometimes SDK gives an error working in the windows 10 environment. You can update the version of the SDK. If your Windows 10 is not working then please contact Windows Tech Support for the proper solution.
