rfeneon
SDK 2017.4/Windows: cannot build library with large number of files
I was unable to generate a library (cortex-r5) with a large number of files on Windows, armr5-none-eabi-ar returning a 'file not found' error for an object, the problem is that the object file exists and has been correctly compiled, but the filename passed to the archiver is corrupted.
It's seems this could be an issue with the length of the command line, on windows cmd.exe has a limitation of 8192 characters for the command line which can be problematic if it is involved to call 'ar' with a large number of files.
I have solved the problem by remplacing the make.exe in SDK/gnuwin/bin with a version (4.2.1) that I have downloaded and compiled myself directly from the gnu make site www.gnu.org/software/make, you should consider to update the version actually shipped with the sdk if it's the cause of the problem.
ibaie
Hi @rfeneon,
Thanks for you feedback, I will rise this issue to the engineering team to make them aware of this issue.
Best Regards,
Ibai
Ibai
ibaie
Hi @rfeneon,
Best Regards,
Ibai
Ibai
rfeneon
Thanks!
