me_sur
SDK 2017.4 issue AR#66322 still presenting itself
The issue described in AR#66322 started presenting itself at least when using AXI4 Lite IP created in a previous version.
The low/high addresses in xparameters are just zeros and Fs.
Is there a clean fix for this or is modifying the Parameters by hand every time the only solution?
me_sur
it seems the issue is that in the conversion of the IP the address offset parameters got set to 0, and manually setting them back to the usual values is useless as they get set to 0 again upon repackaging. This happened only with some IP.
