legendbb
SDK 2018.2 Debug frequently stops in asm_vector.S IRQInterruptHandler
Target board: zcu102, xczu9cg, issue can be reproduced by debugging lwip_echo application.
I've already tried applying patch by method 1 https://forums.xilinx.com/t5/Embedded-Development-Tools/Step-over-during-debugging-stops-at-interrupt-vector/td-p/888385
This makes stepping code almost impossible.
Tags (3)
ibaie
Hi @legendbb,
Did you use the patch posted in the Forum post or the one from the Answer Record? Take care that the one posted in the forum is not fully working!!
Ibai
ibaie
Hi @legendbb
Not sure if you link to the forum post is the right one because it does not provide any patch and neither the AR#64252 referenced within it.
It would be a good idea to describe bit more your issue, what kind of device/board are you using, what kind of application.... otherwise you will see that community will not engage with your post.
Without having more details, might be this your issue? If so there is already a patch published on AR#62132.
Ibai
legendbb
Thanks for feedback, updated original post.
ibaie
Hi @legendbb,
Ibai
