SDK 2018.2
Re: SDK 2018.2
Hi @feixuna,
What is the issue? I am not seeing any description about the issue.
Thanks & Regards,
Praveen Kumar. V
Re: SDK 2018.2
我执行的main函数的第一条就是打印信息,但是执行后没有main的执行结果,只有上面的显示信息。
Re: SDK 2018.2
Hi @feixuna
Please share the screenshot of Application tab.
It is required to enable the 'Download' checkbox for a53_0.
else, elf will not be downloaded to the target.
Best Regards,
Nutan
Re: SDK 2018.2
Re: SDK 2018.2
hi, @nutang
application tap是上面的截图
Re: SDK 2018.2
hi @feixuna
Please refer below link, to do proper configuration.
https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/SDK_tasks/sdk_working_with_GDB.html?hl=gdb
Best Regards,
Nutan
Re: SDK 2018.2
hi, @nutang
Re: SDK 2018.2
hi @feixuna
What happens when you click on resume?
Best Regards,
Nutan
Re: SDK 2018.2
hi, @nutang
click Resume
Re: SDK 2018.2
Hi @feixuna
Have you tried using system debugger?
Best Regards,
Nutan
Re: SDK 2018.2
hi, @nutang
    system debug 后,resume后console没有反应,stop后界面如下
Re: SDK 2018.2
Hello @feixuna
Please share the SDK log
Best Regards,
Nutan
Re: SDK 2018.2
