07-25-2019 07:15 AM
I started getting the following error when starting up SDK.
16:17:15 ERROR : Unsatisfied link error while loading librdi_repo_manager.dll: java.lang.UnsatisfiedLinkError: no librdi_repo_manager in java.library.path
16:17:15 INFO : Launching XSCT server: xsct.bat -interactive C:\Xilinx\WorkSpace\temp_xsdb_launch_script.tcl
16:17:15 ERROR : Error launching XSCT server
java.io.IOException: Cannot run program "xsct.bat": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
at com.xilinx.sdk.xsdb.XSDBCommandManager.launchXsdbServer(XSDBCommandManager.java:283)
at com.xilinx.sdk.xsdb.XSDBCommandManager.ensureServerIsLaunched(XSDBCommandManager.java:168)
at com.xilinx.sdk.xsdb.XSDBCommandManager.access$1(XSDBCommandManager.java:166)
at com.xilinx.sdk.xsdb.XSDBCommandManager$2.run(XSDBCommandManager.java:137)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
I am on Windows10 running SDK 2018.3. I tried re-installing 2018.3 but no change.
I am a newbee to SDK and was in the process of moving my GIT local repo's and where my workspace were located when I started getting this.
In addition I had a workspace setup part way but was unable to build it. An attempt to "build all " resulted in errors indicating "make" not found . But I deleted that workspace as part of my clean-up.
08-27-2019 06:59 AM
I believe the issue is a result of my pinning what I thought was the SDK tool to my windows task bar.
If I start it up with the pinned task, I get these errors. But if I start it up from the xilinx folder fromt the windows start menu it appears to be working fine with none of these errors..
