Observer nvl1109
SDK 2018.3 Ultrascale+ MPSOC R5 FPU enable
Hi all,
I'm using SDK 2018.3 to create an application for R5 core, FreeRTOS enabled. Everything is fine except floating point calculation.
1. I'm unable to enable -mfloat-abi=hard in extra compiler options, I tried to append -mfloat-abi=hard into extra_compiler_flags but it is removed when I re-generate the BSP. Only -mfloat-abi=soft is accepted.
2. In code, I use atof() function to convert string into float number, but it causes un-predictable behaviour in my code flow. If I comment these atof() callings, the program works fine.
Do anyones has expierience about this or any idea to resolve this? Thank you so much.
Tags (4)
Re: SDK 2018.3 Ultrascale+ MPSOC R5 FPU enable
1.  -mfloat-abi=hard is already enabled in BSP settings, that we can see in your screen shot as well (under default section).
2. Can you tell me what is the exact error that you are facing with atof() function.
I tried below example and it is working fine:
#include <stdio.h>
#include <stdlib.h>
int main()
char a[10] = "3.14";
float pi = atof(a);
printf("Value of pi = %f\n", pi);
return 0;
If possible please share your source code so that we can debug it better.
Nagaraju
