SDK - Archiver Flags
Hello!
How to set MicroBlaze "Archiver flags" through Xilinx Software Command Line?
If you type "sdk configapp -help" it will list options bellow: (there is no option for setting "archiver flags")
  assembler-flags
  build-config
  compiler-misc
  compiler-optimization
  define-compiler-symbols
  include-path
  libraries
  library-search-path
  linker-misc
  linker-script
  undef-compiler-symbols
Hi @n.horvat
I think that there is no support to change the archiver flags from the command line tool. I will recheck it internally but no all the options available within the GUI are available right now in XSCT.
Ibai
Ibai
