SDK Compilation error about aarch64-linux-gnu: Can't find -lgcc_s
Hi there,
I got a compiling error when I try to build a C++ project. The error is shown blew:
Building target: ORBSLAM2.elf
Invoking: ARM v8 g++ linker
aarch64-linux-gnu-g++ -L../../standalone_bsp_1/psu_cortexa53_0/lib -Xlinker -sysroot=/home/jason/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu -Wl,-T -Wl,../src/lscript.ld -L/home/jason/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/lib64 -L/home/jason/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/ -o "ORBSLAM2.elf"  ./src/ORBextractor.o ./src/ORBmatcher.o ./src/converter.o ./src/frame.o ./src/frameDrawer.o ./src/initializer.o ./src/keyFrame.o ./src/keyFrameDatabase.o ./src/localMapping.o ./src/loopClosing.o ./src/main.o ./src/map.o ./src/mapDrawer.o ./src/mapPoint.o ./src/optimizer.o ./src/pnPsolver.o ./src/sim3Solver.o ./src/system.o ./src/tracking.o   -Wl,--start-group,-lxil,-lgcc,-lc,-lstdc++,--end-group,-N
/home/jason/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: Can't find -lgcc_s
makefile:48: recipe for target 'ORBSLAM2.elf' failed
collect2: error: ld returned 1 exit status
make: *** [ORBSLAM2.elf] Error 1
And I can find the libgcc_s.so file at /home/jason/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/lib64. As picture showed.
How can I set the library or environment to avoid this problem? I have tried lots of methods such as input the path in linker(as picture shows below) but all of them didn't work for me.
Could anyone please tell me how to deal this problem? Thanks in advance.
Best wishes.
Re: SDK Compilation error about aarch64-linux-gnu: Can't find -lgcc_s
Hi @Jiasen,
Please add the library path under the "-L" option, found in the "Libraries" section as shown below:
(screenshot taken from this wiki_page)
Best regards,
Abdallah
Hi @Jiasen,
Best regards,
Abdallah
Thanks for your solution and it works. Furthermore, I get a new compiling problem about 'undefined reference to __libc_init_array'. The link is https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-failed-to-compile-with-error-of-undefined-reference-to-libc/m-p/1113386#M53764. Could you please give me any idea with that?
