SDK Error When Creating BSP Sources ("mb-ar": no such file or directory)
I work on a project with Vivado 2014.4.
My operating system is Debian Wheezy 7.8.
When I launch the SDK I get the following error while I try to create a new Xilinx Project.
It seems that it fails while trying to create the BSP sources.
15:40:14 ERROR : [Hsi 55-1545] Problem running tcl command ::sw_standalone_v4_2::post_generate : couldn't execute "mb-ar": no such file or directory
while executing
"exec $archiver -d $libgloss_a _interrupt_handler.o"
(procedure "::sw_standalone_v4_2::post_generate" line 18)
invoked from within
"::sw_standalone_v4_2::post_generate standalone"
[Hsi 55-1443] Error(s) while running TCL procedure post_generate()
15:40:14 ERROR : Error generating bsp sources: Failed to generate BSP.
Could the problem be any missing packages?
Thank you!
Re: SDK Error When Creating BSP Sources ("mb-ar": no such file or directory)
I found the solution to my problem and I reply it in case it is useful to anyone.
According to the link below I had to install the ia32-libs package.
http://unix.stackexchange.com/questions/12956/how-do-i-run-32-bit-programs-on-a-64-bit-debian-ubuntu
