rickyalbert
SDK - Memory dump from console
Hi everybody, I need to create a script that every second does a memory dump of the same portion of DDR of my ZedBoard and saves it into a binary file on my PC. The memory dump using the GUI works fine, but I need something on console more sophisticated. Do you know can I achieve that?
Thank you very much
athandr
in the xmd or xsdk SDK console the below commands work to get a dump of any interface connected through AXI from the processor (microblaze or arm). Below are the commands
mrd <address> <number> - this gives the dump from the starting address to the next <number> amount of addresses. You can choose to dump it to a TCL file.
Anirudh
rickyalbert
HI Anirudh, how can I dump the output of mrd into a tcl file? Anyway mrd/mwr work on xmd console but in xsdb I get "Context does not support memory read. Unsupported command"
rickyalbert
I also read that I can use memory dump on GDB, which is used as sdk debugger. However I don't know where to use these commands:
https://sourceware.org/gdb/onlinedocs/gdb/Dump_002fRestore-Files.html
sampatd
rickyalbert
Thank you, I had already read that post. The problem is that I can't find anywhere in my project the output file, it seems that it's not created. Does that method work with Windows?
sampatd
It should. You can try issuing the tcl commands in XSDB console if XMD does not work.
Let me know the outcome.
