tuan94@
SDK Software.Xil_In32,Xil_Out32 Problem
Hi everyone,
I have a project on SDK.
When I connected the Block Design and mapping to SDK.
I want to using the function :Xil_In32(Add),
                                             and Xil_Out32(Add,Value)
but i don't know how to get the value after I do it
EXAMPLE:  I am using     Xil_In32(add)     ,this function are  read I/O and return the value I/O,but I don't know how to get that value
after it was read from different Add.
If you have an ideal and an example,please give me.
Thank you very much,
tuan,
sadanan
Hi tuan94@
Do you mean you want to use the value at addr in your application, when you call Xil_In32(addr)? If so, its as simple as u32 val = Xil_In32(addr), and then do whatever with the variable val
sadanan
Hi tuan94@
