Observer deepika07
(SDK) Unable to connect to ps7_cortexa9
Hi!
I can see the FPGA Connected to the computer but it is not detecting the ARM Processor.
The error is:
I am using zc706. I can upload the bitstream but after that, I am not able to run an application.
I am stuck with this problem and there is no change in the error whatever I do. Please help! I have a hard deadline for a task.
Re: (SDK) Unable to connect to ps7_cortexa9
Hi @deepika07,
As the error message is pointing the System Debugger is not able to find the processor in the target so cannot download the application to it.
On which boot mode are you booting the board?
Did you test a pre-build image and ensure the system is able to boot properly and there is no hardware error?
For further testing you can use the XSCT console (either in the GUI or launching outside) connect to the target and use "targets" command to list the available devices in the chain..
Ibai
Ibai
Observer deepika07
@ibaie
Thanks or your reply!
I booted the board in standalone Mode.
I tested the prebuild image and it was working fine.
I tried with another system and was able to connect it.
I will try to use the XSCT console if I again have the same issue
Thanks!
