SDK: Unique post-build steps for C Project referencing multiple BSPs/HW Platforms
I have source code that is used on a dev kit and a custom board. To avoid two instances of the C Project with each referencing its unique BSP I have one. When I want to build for a specific HW platform I simply Change Referenced BSP.
The problem is that I have unique post-build scripts (right-click C Project > C/C++ Build Settings > Builds Steps tab > Post-build steps) for each platform.
Q: Is there a way to pass a parameter (like a variable) to my script that identifies the currently select BSP and/or HW Platform?
Participant yaswant
Re: SDK: Unique post-build steps for C Project referencing multiple BSPs/HW Platforms
SDK/eclipse stores the dependent projects information in a file called “.project”, which exists in the project directory. Dependent project information can be seen under the <projects> tag of .project file as shown below.
       <projects>
              <project>hello_bsp</project>
       </projects>
In your script, write a small piece of code to parse .project file and get the dependent project information.
Hope this will help you.
Yaswanth
Participant yaswant
       <projects>
       </projects>
Yaswanth
Great idea! Thanks.
Now if I could only do the same for the .ld file (Linker Script).
