Visitor nekips
SDK and LWIP
In C++ under SDK 9.2 SP2 (using xilkernel 3.00.a and lwip 2.00.a) with the xilkernel and lwip4 library,
I've got a compilation problem with the xilinx web server code example.
The lwip function "lwip_init()" seems to be unavailable.
The compiler give me the following error :
error: 'lwip_init' was not declared in this scope
All of the others functions compile.
Please note that everything works fine under EDK with the SAME plateform settings options.
Any idea ?
Message Edited by nekips on 01-22-2008 10:44 AM
Message Edited by nekips on 01-22-2008 10:53 AM
Visitor nekips
Re: SDK and LWIP
I've found the solution, it only happend when your code is in C++.
To build successfully :
#if defined(__cplusplus)
extern "C"
    #endif
    #include "netif/xemacliteif.h"
    extern int lwip_init ();
#endif
Re: SDK and LWIP
also, note that lwip-1.2.0 itself cannot be compiled with C++. The next release of lwIP supports C++ compilation, so until then you have to use C (or manually wrap everything with extern C similar to your solution).
Visitor srojas
Re: SDK and LWIP
just as an supplement to the answer from @nekips, I wanted to add that you should make sure that the lwip library is linked. Check for the following flags:
Right Click project in Project Explorer, choose C/C++ Settings->C/C++ General->Paths and Symbols->Libraries includes
   -Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,--end-group
For more details see the answer of @schmidtf in
https://forums.xilinx.com/t5/Embedded-Development-Tools/How-to-transfer-data-from-PC-to-board-using-LWIP/td-p/257254
