SDK auto sync of new hdf stopped working
I have separate Vivado (PL)  and SDK (PS) projects.
I have been making changes on the PL side and copying the .hdf (including bitstream) file to the root of the SDK project.
SDK was detecting a new hdf and re-building the BSP, etc.
Afterward, there would be an updated system.hdf (regardless of the Vivado hdf's name) in the system_hw_platform_0 directory.
For some reason, SDK stopped detecting new hdf files after copying them to the root of the SDK project.
It does not pop up the box that warns of a new hdf and lets you click OK to rebuild based on the new hdf.
I can manually refresh or clean the BSP and it rebuilds.
The bit file seems to be updating.
However the system.hdf in the system_hw_platform_0 directory has an older date.
It is also acting like the previous PL version is in force.
How can I get SDK to start auto-syncing again?
Emmett
Re: SDK auto sync of new hdf stopped working
Hi @emmettbradford
You can right-click in the hardware_project and select "Change Hardware Platform Specification" which actually changes the reference HDF file. I guess that if you just select again the new HDF file it should handle it.
If not wrong this information is saved within the workspace metada.
Ibai
Ibai
Hi @emmettbradford
Which release of the tool are you using? If 2017.2, there is a well known issue that doesn't update the hardware_platform design in the SDK when re-exporting a new HDF file AR#69489
Ibai
Hi ibaie,
Thanks for your reply.
That seems to be exactly what I am talking about.
However, I am using 2016.3 and don't want to upgrade in the middle of a project.
It was working fine until now, although I had co-worker that had the same trouble w/ SDK 2016.3.
Is there a project setting somewhere?
Emmett
Hi @emmettbradford
If you are using 2016.3 you should not be facing the same issue, as this only has been found in 2017.2
BTW: from your first post it seems that you are manually copying the HDF file from vivado project structure to you SDK. I would recommend you to use the export hardware function in vivado instead, take a look if that way you are still facing the issue.
Ibai
Ibai
I tried exporting to the SDK project directly from Vivado - no difference seen.
Previously I had always exported local to project, where I have an SDK project for simple tests of changes.
Then I copy to the main SDK project, which always detected a new hdf.
I was also able to email the hdf to other team members, some who had the same trouble.
How does SDK know where to look for a new hdf?
Hi @emmettbradford
Ibai
Ibai
That was it!
The field was blank.
I specified the hdf where I copy it, but I don't know if the selection will persist.
At least I know how to manually do it.
Thanks so much,
Emmett
