SDK bsp xil-crt0.s error/bug
so when i generate the zynq FSBL_BSP is run fine.  but after setting up lwip, xilmfs
i got this error under
cortex0 standalone 5.0 folder, file xil-crt0.s  line 180 something
/*let her rip */
bl main
error says undefine main.
try build clean up, rebuild after unselect all lwip, xilmfs etc never fix it.
using vivado 2015.1
any ideas?
Re: SDK bsp xil-crt0.s error/bug
Me too getting same problem..... any solution u found??
This issued happened to me recently , too. I just wrote a new line "bl main" as below and it worked.
I don't know why.
/*let her rip */
//bl main
bl main
