sdhunna
SDK build errors related to profiling when project located outside eclipse workspace
If I build a project, any project, even the free rtos hello world project in a directory outside the eclipse workspace I get build errors due to profiling.  I've checked other posts and confirmed that profiling is not enabled.
If however, I build the same project and it was created in the default location (i.e. inside the eclipse workspace), it builds fine.  I'm looking for a way to locate my project ouside the eclipse workspace directory because that's my preference.
I've attached logs for both situations for the exact same hello world example code.  SDK 2018.3
abouassi
Hi @sdhunna,
It seems to be a bug in the SDK when creating a new application outside the workspace with a new BSP at the same time, that the SDK will create the BSP project folder "inside" the application project and thus the compilation issue you are facing
I'm reporting this internally from my side. But as a workaround, you should first create a BSP project, then create an application project and use the created BSP as an existing BSP instead of creating a new one.
Best regards,
Abdallah
abouassi
Hi @sdhunna,
Best regards,
Abdallah
sdhunna
I can confirm the workaround works.  Thanks for the prompt respond and raising it internally.
