Observer ayda1
SDK c function to HDL
Hi everybody,
I have a microblaze sdk project for Virtex-6. There is a time consuming function in my C code. Is there any way to implement this function via fpga resources? I mean, convert c  function to hdl to speeding up. There is a similar option in Altera Quartus for NIOS which is very easy to use. I do not need hdl code, I only concern for hardware implementation of c function, instead of software implementation.
Scholar austin
Re: SDK c function to HDL
Observer ayda1
Thanks for your respond. It was a big help. I think "Export RTL -> Pcore for EDK" is my answer. I am not sure yet. let me check it.
Observer ayda1
I watched the video. They were really helpful. I could definitely use VIVADO HLS, but I need to add some new HDL codes to current pcore block. This is time consuming. Is there any way that I could use HDL for one of my function inside Microblaze and keep the C code for the rest of my code. For example, when one of my function takes time, I could use HDL for that function. I recall in old Quartus version (6) I do this by right click on the function name and choose appropriate option inside NIOS. After that I could not debug the function, but the function execution time improved significantly.
