arcking0
SDK can not find zynq device
I use SDK which is connected to ZedBoard through Platform Cable USB to debug firmware on zynq.When I debug, SDK can not find zynq.The error information reported is shown as Picture1.Then I use XSCT to check and it shows as Picture2.But it is strange that Vivado can find the device.If I use USB_PROG on ZedBoard,SDK can find it successfully.
Picture1Picture1Picture2Picture2Vivado can find the deviceVivado can find the deviceUSB_PROG connectionUSB_PROG connection
ibaie
Hi @arcking0,
What do you mean if you use USB_PROG? is that a USB-JTAG port in the zedboard?
Ibai
