SDK cant set a breakpoint in a Xilinx file
I am trying to debug a serial flash file in SDK 2018.1. When I place a breakpoint I get the error shown below. Does anyone know how to resolve this? Thanks
回复: SDK cant set a breakpoint in a Xilinx file
The code you're referring to is part of BSP, which is built with optimizations enabled. To debug this code, you need to disable optimizations. In BSP settings dialog, click on the CPU driver from left side pane, and add "-O0 -g3" to extra_compiler_flags. Rebuild the BSP, and then you should be able to debug the code you're referring to
hi @beandigital
i've had a similar problem. I don't know how to solve this problem.
But you can print out the data that you want to see through the serial port so as to avoid the above problem.
Thanks for the info. But it would be good to be able to debug the code!
