mgdudhat
SDK debugging Error - Can not stope Microblaze, Stalled on memeory access
Hi all,
i would like to share with you about one error which i am getting during debugging in sdk as follows:
-once i am resuming the debugging in the software project and then stopping then it shows me following error message:
  -->Can not stope Microblaze, Stalled on memeory access
Due to this error i can not go ahead in debugging. I have attached the snapshot of the error. Your suggestions and advices are highly appreciated.
Thank you.
ibaie
Hi @mgdudhat
The debugger is trying to access to both processor registers and memory content when you stop the execution, and it seems that an issue is happening on that process. Could you provide more details about your use case? i.e. from which memory is executing MB when you try to stop?
Ibai
Thimmanagowda
Hi @ibaie i am also facing the same issue when trying to access DDR3 from microblaze
I am trying to Write and Read from DDR3, while debugging but microblaze is running continuously after writing to some locations and is not allowing debugging or not writing to remaining locations
I have attached my design for your reference any suggestions will be helpful
Thank You
