Visitor feihu612
SDK download problems,everyone must pay attention!!!
I first download the fpga bit file into fpga, just as the picture below:
then , I go the project area,  and select " Run As ---> launch On Hardware ",  so the software is now running in FPGA!
OK,  good,  we can get the right result!!!
However,  now , I want to  use the fpga bit file and the software elf file together download to fpga, just like the picture below:
the problem comes:
the test results is :  the fpga get right data from the microblaze software  through AXI4 interface, but the fpga can not get data from DDR3 through AXI4 interface, the axi4 " ready " signal is always busy to fpga.
the mb software and fpga both attach to DDR3 by AXI4 interface!
who can help me ? thanks very very much!
sdh switch pcie qq community: 292877592
Visitor feihu612
Re: SDK download problems,everyone must pay attention!!!
someone told me to modify the lscript.ld file, but i think no need to modify,just below:3.jpg
Did you try from Generate Linker Script window on application?
Praveen
