Advisor
Advisor
SDK editor - can I edit 2 different source files side-by-side (split editor window)
Using SDK 2018.2
In SDK, clicking Window -> Editor -> Toggle split editor allows me to have 2 views on the same source file.
Is it possible to view/edit 2 different source files side-by-side using the split editor function?
Hi @ronnywebers
Yes, it is possible. You just need to drag the tab where you have the file to the editor and it would allow you to split the window either in vertical mode or horizontal mode. Afterwards you can keep the editor window splited with the whole perspective or maximize the window to have the whole GUI with the dual editor.
Ibai
Hi @ronnywebers
Ibai
