anis1133
SDK error "initialize s/w repositories"
HI xilinx ,
I have encountered a problem with SDK for Vivado 2018.1
When launching SDK from a Vivado project, my installation won't connect to XSCT server and won't initialize s/w repositories.
please help me. thank you
anunesgu
Hi @anis1133 ,
As it is mentioned in the error message, your workspace location contains a space in it's name, which is not acceptable for the tool.
Looking at the screenshot, I see that the worskpace was created in C:\Users\Amine Info\...
You'll need to remove that space from the path name and try creating a new project and a new workspace.
Andre Guerrero
Product Applications Engineer
