vinogradov_rus
SDK flash program command
I'd like to use script for automatic building, creating bootimage and QSPI flash programming
For building and creating bootimage commands found quickly
http://www.wiki.xilinx.com/Prepare+boot+image
But for memory programing found only GUI way
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/SDK_Doc/SDK_references/sdk_u_program_flash.html
Is there command for flash programming?
sampatd
You can use the command "program_flash"
sampatd
jrp
Re: But for memory programing found only GUI way
Broken link...
DOWN VOTE - no kudo for you
