SDK initial folder when selecting Xilinx > Create Boot File
Is the guy who made that entertaining random initial folder still working at Xilinx?
I just created a project, brand new, compiled, did Generate boot and started into a folder in that project. That's fine.
Did some changes in the code, compiled again, went to generate again and, ta-dah, it started somewhere in a previous project. Amazing.
Re: SDK initial folder when selecting Xilinx > Create Boot File
Hi @satguy
It's good to see that you take this issue with some humor :)
Not sure if I understood the problem properly, could you provide some more information an maybe some screenshots? It seems that you are complaining the the boot image folder selected by the "Boot Image generator wizard" is kind of random?
BTW: Which version of the tool are you using?
Ibai
