xdtech
SDK:ld.exe cannot find a lib file
hi community,
I am a freshman in the Xilinx Forum,and got a trouble when using the SDK ,please give me some advice.
I want to test the HDMI interface of the KC705,and use the ADV7511 Design Demo (https://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511)
One of the steps is to specify the location of the library,and then I got stuck in there.
In SDK, I want to add a lib file for the project,the method is change the value in project->properties->settings->'library search path' and 'library' parameter.But the build system strangely told me it cannot find the file.
problem 1:
the library file ADV7511 provided is a compressed file with the '.a' suffix, Is it a right library pattern? Should I uncompressed the file before I specify the path?(when I uncompress the file ,a lot of .o files contained in the folder)
problem2:
There does exist the target file in the location,why the script 'ld.exe' couldn't recognize it?
My Env:
win10  +  vivado 2016.4 + SDK 2016.4 + KC705 + HDMI
Any ideas from you will be appreciated!
Tags (2)
ibaie
Hi @xdtech
Welcome to the forum :)
  1. No you don't need to uncrompress the library, static libraries are handled (.a) are handled properly by the toolchain.
  2.  I'm wondering if the path of library location is not the right one. Could you provide the following info?
    1. Console output of the compilation to check you search path
    2. Location (path) of the .a file
Ibai
Ibai
xdtech
Thanks for your reply!!
I post my console record (console.txt) as the attached file.
The first picture below shows the location of the console.txt, The second one shows my project directory.
The absolute path of the lib is
E:\ADV7511_demo\hdmi_test\lib\HDMI_MicroBlazeLib.a
and my workspace of SDK project is
E:\ADV7511_demo
The main description of the error :
'Building target: hdmi_test.elf'
'Invoking: MicroBlaze gcc linker'
mb-gcc -L"E:\ADV7511_demo\hdmi_test\lib" -Wl,-T -Wl,../src/lscript.ld -L../../hdmi_test_bsp/sys_mb/lib -mlittle-endian -mxl-barrel-shift -mxl-pattern-compare -mno-xl-soft-div -mcpu=v10.0 -mno-xl-soft-mul -mxl-multiply-high -Wl,--no-relax -o "hdmi_test.elf" ./src/cf_hdmi.o ./src/main.o ./src/transmitter.o -lHDMI_MicroBlazeLib -Wl,--start-group,-lxil,-lgcc,-lc,--end-group
d:/vivadotemp/sdk/2016.4/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/5.2.0/../../../../microblaze-xilinx-elf/bin/ld.exe: cannot find -lHDMI_MicroBlazeLib
collect2.exe: error: ld returned 1 exit status
ibaie
Hi @xdtech
It's seems bit strange, I mean, the search path in the settings looks fine as far as the library is located there (from the workspace image seems too).
I will suggest you to test changing the location of the library to different folder (i.e. C:\) and test if that works. Also check the usage of / and \.
PD: If you share the HDF file and the .a library we could test if it does not work for you.
Ibai
Ibai
ericv
@xdtech
try this:
rename your library to start with "lib"; in your case libHDMI_MicroBlazeLib.a.
I believe the linker expects all library names to start by lib.
e.g. when linking with the math library (the file is named libm.a), -lm is specified on the command line and not -llibm
