SDK microblaze
After I finished the block design and generated the bitstream, I wanted to run  my code on the microBlaze using a Zedboard so I got this message in SDK.
Re: SDK microblaze
Hi @neder.kerchaoui
As the error messages states, your microblaze processor is in reset state so there is no way you could download the application into the local memory. How are you clocking and controling the reset signal of your Microblaze processor?
A common mistake is to not select the psu_init.tcl initialization in your debug configuration when the MB is clocked from the PS side. If the processor is clocked from the PS then initialization is required to get the clock running.
Ibai
Re: SDK microblaze
This Tcl command is selected but  the problem is  : "Unable to Wake up MicroBlaze"
