sanjivgarg
SDK misindentifying FPGA packages type
I have a FPGA board with a Zynq XA part on it. when I run SDK I get this warning:  "Part name present in the hardware specification 'xa7z020clg484-1Q" doesn't match the one present on the target 'xc7z020'.   I know for a fact that the target does have the xa7z020clg484-1Q part on it because I can see it stamped on the FPGA.
ritakur
which SDK version are you using? please try the latest one, it should be no problem.
there was an issue in the older version.
https://www.xilinx.com/support/answers/58472.html
sanjivgarg
we are using 2018.1 SDK. We can't go to latest one because we are in the middle of a project and all EDA
tool versions have been locked down to avoid any delays in the schdule.
sanjivgarg
I have no issue with programming the FPGA with the bit stream. However, this warning gave us a scare because we thought we were using the wrong part on our boards. It is very important that we have the XA devices.
