Observer ananth
SDK new project error
hi there!!!  i am new to vivado...
i am working with zynq 7000 evaluation and development kit. vivado 2016.2 for audio processing application..
when i try to create a new application in sdk, it gives me 107 errors ... the errors are attached..  your help would be appreciated...
thanks in advance..
Re: SDK new project error
Hi @ananth,
Did you try this on the different OS?
Which OS are you using?
I am predicting that this might be an OS issue.
Best Regards
Abhinay PS
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Hi @ananth,
Best Regards
Abhinay PS
Best Regards
Abhinay PS
Hi @ananth
Please navigate to properties -> C/C++ general -> Paths and symbols
Check if any of the include path, library path are showing warning sign.
If yes, please navigate and update the paths.
Best Regards,
Nutan
Hi @ananth,
Please check the BSP project and make sure this Board support package project built is successful or not.
If BSP project is successful then add the same . Right click on application project--> C/C++ build settings-->Paths
Thanks & Regards,
Praveen Kumar. V
