arrilag
SDK not showing in BSP axi_iic_0
I am using Vivado 2017 and Xilinx SDK 2017.4 with a Zedboard.
In my Vivado block design I had first the ZYNQ configured with I2C-0 and I2C-1 outputs. But then I decided to remove I2C-0 from the ZYNQ and added axi_iic_0 to my design and set its pins to H15 and K15 (1.8V).
However when I open Xilinx SDK with the C-code I wrote earlier, I still see in the Board Support Package ps7_i2c_0 and ps7_i2c_1 with options to import examples, but no axi_iic..
I suspect I messed up the file-structure of my design.
I also tried "Re-generate BSP Sources" but no change...
How do I update the references so that SDK shows me the BSP that belongs to my new hardware design?
Thanks for any help.
arrilag
ok, following this post I added an interrupt controller to the design (axi_intc_0) and that fixed the "fatal error: xintc.h".
I guess that solved my problem.
watari
Hi @arrilag
Did you export hardware design file into SDK, again ?
If no, would you try it ?
Best regards,
arrilag
Hi @watari
Thank you for the quick reply.
I exported the bitstream and re-launched SDK, but still same situation (please see below screenshot):
- I see ps7_i2c_0 and ps7_i2c_1
- no axi_iic even though I have it in the block-design.
arrilag
now I removed ZYNQ and axi_iic from my block-design, put 'new' ZYNQ and axi_iic in the design and recofigured them, then re-ran bit generation, exported the bitstream and opened up a new Application Project in SDK... and now I see the updated BSP with only ps7_i2c_1 and axi_iic_0.
But trying now the xiic_multi_master_example I get the error
../src/xiic_multi_master_example.c:111:19: fatal error: xintc.h: No such file or directory
Thanks for any hint how this can be solved.
arrilag
