Visitor samuele.m
SDK problems with Xilinx application projects
We are experiencing an issue using SDK version 2015.1: we create a Xilinx Application project, work on it and then, without doing anything particular, SDK does not see it as a Xilinx project anymore and the project contextual menu does not show the Xilinx items (for example, we can't associate a new BSP). This problem appeared in older versions too, but now, even if we create a new Xilinx Application Project, Xilinx menu is not shown at all. Is there something we can do to resolve this?
Thank you very much.
Re: SDK problems with Xilinx application projects
This is strange issue. Could you share screenshots of problems seen at your end?
Praveen
Visitor samuele.m
I have some problem sending a screeshot just now, anyway I tried to switch to another workspace and everything started working as usual, so I think something went wrong in the workspace itself...
