hujiang
SDK program FPGA : FPGA configuration encountered errors
 My  Target Board:  is xilinx.com vc707 Rev B.When I  use  EDK13.3,I  can  program FPGA ,but When I use EDK14.3,then FPGA configuration encountered errors. Is there  anybody know why ?
Anonymous
Not applicable
Make sure you close down all other instances of the SDK.
When I see an error like the above, I usually depower the target, close the SDK, force-kill any stray "xmd" processes left behind, then disconnect and reconnect the JTAG adaptor and finally repower the target board and start the SDK.  This usually seems to sort any problems out.
Anonymous
Not applicable
hujiang
thank you !
