SDK segfault on UART output?
Hello All,
I am running ISE Design Suite 12.4 on a 64-bit Ubuntu 10.04 installation.  My board is the Avnet LX9 MicroBoard with a Spartan6 FPGA.
I am working on the first Avnet tutorial, which has the user create a new MicroBlaze system, download it to the board, and then create and run a peripheral test C app on the board.  I get all the way past programming the FPGA (over the USB-JTAG interface) and creating the C program.
However, when I attempt to run the C program, using the Run Configuration procedure in XSDK, I get a seg fault.  The error is below:
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f3c5abe724d, pid=15755, tid=139897136604928
# JRE version: 6.0_16-b01
# Java VM: Java HotSpot(TM) 64-Bit Server VM (14.2-b01 mixed mode linux-amd64)
# Problematic frame:
# C  [librxtxSerial.so+0x724d]  read_byte_array+0x3d
I believe this has something to do with the Silicon Labs CP210x USB to UART driver, which is good news I guess since I CAN program the FPGA (which is really the important part).  However, the driver/device appears to be working fine from a system stand point (it shows up using the Ubuntu 10.04 drivers in both lsusb and dmesg, and correctly populates /dev/ttyUSB0).
I've tried searching both the Avnet and Xilinx forums for anyone with a similar problem to no avail.  Does anyone have any advice on how to fix this issue, or to further debug and pinpoint the issue?
Thanks in advance,
Barry
Hello. I have the same problem on Kubuntu 11.04 with ML605 board. Any solutions?
Thanks, Evgeniy
Replacing the librxtxSerial.so with the new from rxtx2.2pre2 has solved the problem.
Cheers,
Robert
Same issue on Ubuntu 12.10 64bit with 14.4 64 bit.
works with replacing the librxtxSerial.so from the distribbution :
sudo aptitude install librxtx-java
sudo mv /opt2/Xilinx/14.4/ISE_DS/EDK/eclipse/lin64/eclipse/plugins/gnu.io.rxtx.linux.x86_64_2.1.7.3_v20071015/os/linux/x86_64/librxtxSerial.so /opt2/Xilinx/14.4/ISE_DS/EDK/eclipse/lin64/eclipse/plugins/gnu.io.rxtx.linux.x86_64_2.1.7.3_v20071015/os/linux/x86_64/librxtxSerial.so.orig
sudo ln -sf /usr/lib/jni/librxtxSerial.so /opt2/Xilinx/14.4/ISE_DS/EDK/eclipse/lin64/eclipse/plugins/gnu.io.rxtx.linux.x86_64_2.1.7.3_v20071015/os/linux/x86_64/librxtxSerial.so
Anonymous
Not applicable
I have same issue on Ubuntu 13.10 64-bit with v14.4 but with librxtxSerial.so fix as mentioned by pilakkat still crashes.
Any other suggestions?
May 20, 2015
I had similar problems when running Xilinx SDK v14.7 on a RHEL7 system we recently converted as
a  test system since we plan to change all our lab systems to RHEL7.  When downloading the .elf exectuable file
to a ZYNQ board, SDK crashed witht he error message:
xperimental: JNI_OnLoad called.
# SIGSEGV (0xb) at pc=0x00007f40eeeb324d, pid=2857, tid=139916862994176
# JRE version: 6.0_21-b06
# Java VM: Java HotSpot(TM) 64-Bit Server VM (17.0-b16 mixed mode linux-amd64 )
We downloaded the librxtxSerial.so as per one of the above posts, but when we copied it over to
the install directory and re-tested, this time there were messages concerning "unable to obtain lock file"
and SDK reported that  "no such device 'dev/ttyUSB0'  (the serial port the UART uses to communicate between
SDK and  Xilinx board via the JTAG programmer cable".  A little snooping around with the strings command on the
librxtxSerial.so executasble revealed that it tries to write to /var/lock.  On our systems, /var was no world readable,
we chmod'ed 777 /var and it worked fine.  We are now trying to recompile the  librxtxSerial.so object file with
locking diabled, if this doesnt work, we will simply live with the file writing to /var/lock.  It should be noted that
we did not experience this problem hen running either SDK 14.4 or SDK14.7 on RHEL6 systems, only on RHEL7:
the exact version of RHEKL7 is:
3.10.0-229.1.2.el7.x86_64
Interestingly, this problem did not occur when downloading .bit file to the bosrd using Impact.  This is most likely due
to the fact that impact uses the JTAG programmer cable and a different port. SDK uses /dev/ttyUSB0 to establish
a  serial terminal between the board and the host SDK software.
So, it you downloaded the librxtxserial.so file and still have problems, chmod your /var to 777 if you're comfortable
with users having write permission.
The librxtxserial.so that comes installed with SDK is circa version 2.1 from around 2007 , the one we downloaded was circa 2.2 .
Hopefully this information will be of help to others who experienced the same or similar problems.
Ted Obuchowicz
VLSI Specialist/Jumpin' Jack CAD
Concordia University
Just a short follow up:
recompiling the librxtxSerial.so from the source and specifying to disable locking solved the problem and needing
777 file perms on /var/lock.  Yiou can recompile and specify no file locking with :
now go back to the main directory and configure the build with locking disabled, and build it
cd ..
./configure --disable-lockfiles
make
You can get the source code from:
http://rxtx.qbang.org/wiki/index.php/Download
the source file rxtx 2.2pre2.zip and unzip it:
unzip rxtx-2.2pre2.zip
Ted Obuchowicz
Hi Keith_r1,
      I'm having the same problem but I can't seem to understand your steps for recompiling the downloaded rxtx-2.2pre2.zip and unzipped it but not sure how to recompile it and where to put it afterwards. Can you please explain the steps in a little more details.
Thanks!
I have the same problem. I don't understand how to use rxtx-2.2-pre2 to solve the problem
6.5 years later and this is still a problem with 2017.4. The fix described above still works.
Install librxtx-java, if it isn't already installed.
sudo apt-get install librxtx-java
Then replace the existing librxtxSerial.so in the Eclipse plugins directory with a symlink to the newer file (after saving the original file just in case)
cd <XilinxInstallDir>/SDK/2017.4/eclipse/lnx64.o/plugins/gnu.io.rxtx.linux.x86_64_2.1.7.3_v20071015/os/linux/x86_64
mv librxtxSerial.so librxtxSerial.so-original
ln -s /usr/lib/jni/librxtxSerial.so librxtxSerial.so
