SDK tool problem
I am working on XilinxSDK-2014.2 tool and targeting  on Zynq7020 and trying to communicate with the device using the I2C interface. The generated code is working fine, but whenever i build it the code is not working. Even the same code is not working if i create the new project and use the same code along with the same HDF file.
  Can anybody please tell me what would be the problem.
Scholar sampatd
Re: SDK tool problem
Is there any error you see while building the project in SDK?
If so, can you attach the error log?
Moving to correct board.
Thanks,Vijay
hi,
is the existing code based off an older version of driver? what is the application that your code is trying to do?
--hem
Hi ,
There are no errors while building
Hi htsvn,
No, the code is not based on the older version, they are same version.
I am trying to communicate with the peripheral using the I2C, where i am trying to write/read it registers.
Hi Vijayak
I am trying in the same board, just by building it again and targeting the same board.
Scholar sampatd
Have you tested the example code that are provided with the install: You can find them in
<Xilixn Install>\2014.2\data\embeddedsw\XilinxProcessorIPLib\drivers\iicps_v2_3\examples
Hi vijayak,
i tryed with that code its working fine,but we are  using our custamized code please find the attached copy of the code.
thanks you
