Observer zhou
SDK undefined reference to 'exp'
 hello,I got a strange problem about SDK.(I am using sdk 2017.1)
when I use exp function like 'float a =exp(3.0)',it is ok,but when I use 'exp' like :
float a = 9.0;
float b=exp(a);
then it doesn't work,and showing error: 'undefined reference to 'exp''.
Scholar hbucher
Re: SDK undefined reference to 'exp'
@zhou You have to link against the math library
https://www.xilinx.com/support/answers/52971.html
Scholar hbucher
Observer zhou
it is different from mine,I cann't find the right place.
Scholar hbucher
@zhou There are several tabs missing
Try hitting "Restore Defaults"
To Address this, right click on the application and select C/C++ Build Settings, and include the math lib:
Scholar hbucher
@stephenm Problem is that his settings Are missing those Configuration panels
Can you send a screenshot of the C/C++ Build settings. Make sure that the Makefile Generation is selected
Observer zhou
回复: SDK undefined reference to 'exp'
i gona to rebuild a project, and try again,thank you for your advice
