SDK undefined reference
I am using Vivado 2017.3 with SDK. In SDK I enable the flash memory library. When I compile the program it complains of undefined reference for all the flash library functions even though the bsp has all the files. I have added the header file in my main, so I cant understand why there is a problem. Can someone explain what the issue is?
The compiler options dont seem to have this set:
--start-group,-lxil,-lgcc,-lc,--end-group
Can you right click on your app in SDK, and select C/C++ build settings. Then under Microblaze gcc linker -> Inferred options -> Software Platform, can you edit this, and add your library here.
For example
Hi @beandigital
It might be that in the project settings of your application project the library has not been included in the linker options. If not wrong that should be automatically done when enabling the library in BSP but you might want to check it.
In the other hand can you post the console output of the compilation? The error message and the compilation command prints are quite usefull to understand what's going wrong when you have a compilation error ;)
Kind Regards,
Ibai
Ibai
This is what I get. Sometimes if I just disable then enable the flash library it works, other times it doesnt. Which settings should I be checking? Also I am now using 2017.4 and the problem still exists.
12:46:24 **** Auto Build of configuration Debug for project flash_mem ****
make all
'Building file: ../src/flash.c'
'Invoking: MicroBlaze gcc compiler'
mb-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"src/flash.o" -I../../flash_mem_bsp/microblaze_0/include -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -ffunction-sections -fdata-sections -MMD -MP -MF"src/flash.d" -MT"src/flash.o" -o "src/flash.o" "../src/flash.c"
'Finished building: ../src/flash.c'
'Building target: flash_mem.elf'
'Invoking: MicroBlaze gcc linker'
mb-gcc -Wl,-T -Wl,../src/lscript.ld -L../../flash_mem_bsp/microblaze_0/lib -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -Wl,--gc-sections -o "flash_mem.elf" ./src/flash.o -Wl,--start-group,-lxil,-lgcc,-lc,--end-group
./src/flash.o: In function `main':
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:86: undefined reference to `XIsf_Initialize'
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:98: undefined reference to `XIsf_WriteEnable'
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:101: undefined reference to `XIsf_Erase'
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:122: undefined reference to `XIsf_WriteEnable'
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:125: undefined reference to `XIsf_Write'
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:145: undefined reference to `XIsf_WriteEnable'
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:148: undefined reference to `XIsf_Read'
./src/flash.o: In function `IsfWaitForFlashNotBusy':
D:\Work\Vivado\g400_001\g400_001.sdk\flash_mem\Debug/../src/flash.c:186: undefined reference to `XIsf_GetStatus'
collect2.exe: error: ld returned 1 exit status
make: *** [flash_mem.elf] Error 1
12:46:30 Build Finished (took 6s.483ms)
For example
Yes that seems to have worked, thanks.
Though I have added those things, in my build f_mount,f_close are still showing undefined reference.Please help me .
Hi @stephenm,
After I added the required library (PmodDA3.h), I got another error.
Here is  a part of the consol output:
'Building target: FH_TX_2.elf'
mb-gcc -L"D:\Users\dell\Vivado_projects\FHSS_Transmitter_2\FHSS_Transmitter_2.sdk\FH_TX_2_bsp\microblaze_0\libsrc" -Wl,-T -Wl,../src/lscript.ld -L"D:\Users\dell\Vivado_projects\FHSS_Transmitter_2\FHSS_Transmitter_2.sdk\FH_TX_2_bsp\microblaze_0\lib" -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -Wl,--gc-sections -o "FH_TX_2.elf" ./src/testperiph.o ./src/xiomodule_selftest_example.o -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,PmodDA3.h,-lxil,-lgcc,-lc,--end-group
d:/xilinx/sdk/2018.2/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/7.2.0/../../../../microblaze-xilinx-elf/bin/ld.exe: cannot find PmodDA3.h: No such file or directory
make: *** [FH_TX_2.elf] Error 1
00:11:55 Build Finished (took 829ms)
_________________________________________________
Looking forward your Help.
Hi, I tried to do the same as u mintioned above. I can't actually edit these setting I don't know why. My error message is as shown . Thanks a lot
*** Build of configuration Debug for project w3_example ****
make all
Building file: ../src/w3_example.c
mb-gcc -Wall -O0 -g3 -I../../w3_TemplateProject_OnBoardPeriphs_v1p3_bsp/microblaze_0/include -c -fmessage-length=0 -mxl-barrel-shift -mxl-pattern-compare -mno-xl-soft-div -mcpu=v8.20.b -mno-xl-soft-mul -MMD -MP -MF"src/w3_example.d" -MT"src/w3_example.d" -o"src/w3_example.o" "../src/w3_example.c"
Finished building: ../src/w3_example.c
Building target: w3_example.elf
mb-gcc -Wl,-T -Wl,../src/lscript.ld -L../../w3_TemplateProject_OnBoardPeriphs_v1p3_bsp/microblaze_0/lib -mxl-barrel-shift -mxl-pattern-compare -mno-xl-soft-div -mcpu=v8.20.b -mno-xl-soft-mul -o"w3_example.elf" ./src/w3_example.o -Wl,--start-group,-lxil,-lgcc,-lc,--end-group
./src/w3_example.o: In function `main':
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:44: undefined reference to `w3_eeprom_readSerialNum'
./src/w3_example.o: In function `userio_example':
makefile:39: recipe for target 'w3_example.elf' failed
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:71: undefined reference to `microblaze_enable_exceptions'
./src/w3_example.o: In function `w3_node_init':
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:76: undefined reference to `clk_init'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:84: undefined reference to `ad_init'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:91: undefined reference to `radio_controller_init'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:97: undefined reference to `iic_eeprom_init'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:103: undefined reference to `XTmrCtr_Initialize'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:110: undefined reference to `XTmrCtr_SetOptions'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:120: undefined reference to `XTmrCtr_SetResetValue'
./src/w3_example.o: In function `usleep':
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:123: undefined reference to `XTmrCtr_Start'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:125: undefined reference to `XTmrCtr_IsExpired'
/home/abdelsalam/Desktop/Abdelsalam_research/Project_1/w3_TemplateProject_OnBoardPeriphs_v1p3/SDK_workspace/w3_example/Debug/../src/w3_example.c:130: undefined reference to `XTmrCtr_Reset'
/opt/Xilinx/13.4/ISE_DS/EDK/gnu/microblaze/lin64/bin/../lib/gcc/microblaze-xilinx-elf/4.1.2/../../../../microblaze-xilinx-elf/lib/bs/m/libxil.a(xil_printf.o): In function `padding':
/proj/epdsw/gnu/mb_gnu/src/gcc/libgloss/microblaze/xil_printf.c:50: undefined reference to `outbyte'
/opt/Xilinx/13.4/ISE_DS/EDK/gnu/microblaze/lin64/bin/../lib/gcc/microblaze-xilinx-elf/4.1.2/../../../../microblaze-xilinx-elf/lib/bs/m/libxil.a(xil_printf.o): In function `outnum':
/proj/epdsw/gnu/mb_gnu/src/gcc/libgloss/microblaze/xil_printf.c:111: undefined reference to `outbyte'
/opt/Xilinx/13.4/ISE_DS/EDK/gnu/microblaze/lin64/bin/../lib/gcc/microblaze-xilinx-elf/4.1.2/../../../../microblaze-xilinx-elf/lib/bs/m/libxil.a(xil_printf.o): In function `xil_printf':
/proj/epdsw/gnu/mb_gnu/src/gcc/libgloss/microblaze/xil_printf.c:163: undefined reference to `outbyte'
/proj/epdsw/gnu/mb_gnu/src/gcc/libgloss/microblaze/xil_printf.c:260: undefined reference to `outbyte'
/proj/epdsw/gnu/mb_gnu/src/gcc/libgloss/microblaze/xil_printf.c:233: undefined reference to `outbyte'
/opt/Xilinx/13.4/ISE_DS/EDK/gnu/microblaze/lin64/bin/../lib/gcc/microblaze-xilinx-elf/4.1.2/../../../../microblaze-xilinx-elf/lib/bs/m/libxil.a(xil_printf.o):/proj/epdsw/gnu/mb_gnu/src/gcc/libgloss/microblaze/xil_printf.c:229: more undefined references to `outbyte' follow
collect2: ld returned 1 exit status
make: *** [w3_example.elf] Error 1
Hi @abdelsalam ,
Could you plz, post a screen shot for the "Problems" tab . It may be help ma to indicate your error.
@ahmed_alfadhelThanks a lot for your replay.
In the follwing, pictures from the error message. And another one for the seeting which I can't edit
Thanks a lot in advance.
Welcome @abdelsalam ,
I meant , the "Porblems" tab :Capture.JPG
I want screenshot for it.
@ahmed_alfadhel  Hello.
finally I manged to solve the problem I was facing.
My actual error was this one "/bin/bash: gmake: command not found" and because I'm using upuntu I needed to run this line in my command window first,
"sudo ln -s /usr/bin/make /usr/bin/gmake"
And that solve the problem
Thank You for your help I appriciated.
It looks like you mistyped lxilisf
can you please tell me what did you write exactly in software platform inferred flag area to make it work?
