SDK undefined reference
I was using xilffs to get file system data from SD card. In BSP setting, I enabled xilffs. the initial compile works file. However, after a few days, when re-open the project, the whole project always need to be recompiled (seems common to SDK). Then I ran into an error: undefined reference to f_mount. The only way I can fix is to unselect the xilffs in BSP, let it compile, then re-select it. Then error is gone.
Here's the error:
'Building target: zcu106_dptxsf.elf'
'Invoking: ARM v8 gcc linker'
aarch64-none-elf-gcc -Wl,-T -Wl,../src/lscript.ld -L../../zcu106_dptxsf_bsp/psu_cortexa53_0/lib -o "zcu106_dptxsf.elf" ./src/clk_set.o ./src/idt_8t49n24x.o ./src/menus.o ./src/ti_lmk03318.o ./src/xdptxss_zcu106_dp14_tx.o ./src/xedid_print_example.o ./src/xvid_pat_gen.o -Wl,--start-group,-lxil,-lgcc,-lc,--end-group
c:/xilinx/sdk/2019.1/gnu/aarch64/nt/aarch64-none/bin/../lib/gcc/aarch64-none-elf/8.2.0/../../../../aarch64-none-elf/bin/ld.exe: ./src/xdptxss_zcu106_dp14_tx.o: in function `DDR_Pic_Layer_Initialize':
C:\FPGA2019p1\DP\zcu106_dptxsf\dptxsf.sdk\zcu106_dptxsf\Debug/../src/xdptxss_zcu106_dp14_tx.c:2368: undefined reference to `f_mount'
c:/xilinx/sdk/2019.1/gnu/aarch64/nt/aarch64-none/bin/../lib/gcc/aarch64-none-elf/8.2.0/../../../../aarch64-none-elf/bin/ld.exe: C:\FPGA2019p1\DP\zcu106_dptxsf\dptxsf.sdk\zcu106_dptxsf\Debug/../src/xdptxss_zcu106_dp14_tx.c:2375: undefined reference to `f_mount'
c:/xilinx/sdk/2019.1/gnu/aarch64/nt/aarch64-none/bin/../lib/gcc/aarch64-none-elf/8.2.0/../../../../aarch64-none-elf/bin/ld.exe: C:\FPGA2019p1\DP\zcu106_dptxsf\dptxsf.sdk\zcu106_dptxsf\Debug/../src/xdptxss_zcu106_dp14_tx.c:2382: undefined reference to `f_open'
c:/xilinx/sdk/2019.1/gnu/aarch64/nt/aarch64-none/bin/../lib/gcc/aarch64-none-elf/8.2.0/../../../../aarch64-none-elf/bin/ld.exe: C:\FPGA2019p1\DP\zcu106_dptxsf\dptxsf.sdk\zcu106_dptxsf\Debug/../src/xdptxss_zcu106_dp14_tx.c:2395: undefined reference to `f_lseek'
c:/xilinx/sdk/2019.1/gnu/aarch64/nt/aarch64-none/bin/../lib/gcc/aarch64-none-elf/8.2.0/../../../../aarch64-none-elf/bin/ld.exe: C:\FPGA2019p1\DP\zcu106_dptxsf\dptxsf.sdk\zcu106_dptxsf\Debug/../src/xdptxss_zcu106_dp14_tx.c:2401: undefined reference to `f_read'
c:/xilinx/sdk/2019.1/gnu/aarch64/nt/aarch64-none/bin/../lib/gcc/aarch64-none-elf/8.2.0/../../../../aarch64-none-elf/bin/ld.exe: C:\FPGA2019p1\DP\zcu106_dptxsf\dptxsf.sdk\zcu106_dptxsf\Debug/../src/xdptxss_zcu106_dp14_tx.c:2440: undefined reference to `f_close'
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:38: zcu106_dptxsf.elf] Error 1
If open declaration of "f_mount", I can see it in the file ff.h.
I searched online and found the following link:https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-undefined-reference/td-p/818300
Followd that, in my application project, I modified the Software Platform Inferred Flags, and add -lxiffs, re-compile shows in-correct path. Only when I modified the BSP as shown above, the link path can be found.
Is there a way to prevent this from happening?
Thanks and Regards,
Michelle
Re: SDK undefined reference
I dont see the library added here (should be -lxilffs)
Can you right click on the app, and select C/C++ build settings. Then under linker, libraries select the + icon and add xilffs
@stephenm
Thanks. I will give it a try when I run into this problem again.
Michelle
Ok, mark this as solved please. This will help others with similar issue
Just verified it and it works. Thanks!
Michelle
