Voyager
Voyager
SDK won't build in WIN7 (errors out)
I've been having issues with getting microblaze up and running on my custom board.  All I did was say I have one LED (trying to make it easy to start) and did the peripheral test project to test that out.  When it goes to make I get
**** Build of configuration Debug for project peripheral_tests_0 ****
make all
Building file: ../src/testperiph.c
Invoking: MicroBlaze gcc compiler
make: Interrupt/Exception caught (code = 0xc00000fd, addr = 0x4227d3)
 Googling around and searching through the forums, I can see other people having similar issues, and some of them have solved them, but I cannot get past it.  It doesn't look like I have spaces or parenthesis in my path to the project.  I tried mucking with the PATH variable to try to point to mb-gcc, but that didn't help.  I unfortunatly can't seem to get more debug output than what is shown above.
Does anyone else have any other ideas?  I am using 13.4 in windows 7.
Re: SDK won't build in WIN7 (errors out)
I discovered taht the problem in the Path variable was this C:\Program Files (x86)\Git\bin;
Removing this value from the Path now SDK works fine. I'm not sure, but I think this is due to some similar libraries presents in both installation SDK and Git.
Antonello
Voyager
Voyager
I tried following the tutorial in UG683 and am still having the same issues.  It seems like it is having an issue with an include since in a different log file I can see this:
make -k all
libgen -hw ../hw_platform_0/system.xml\
	       -pe microblaze_0 \
	       -log libgen.log \
	       system.mss
libgen
Xilinx EDK 13.4 Build EDK_O.87xd
Copyright (c) 1995-2011 Xilinx, Inc.  All rights reserved.
Command Line: libgen -hw ../hw_platform_0/system.xml -pe microblaze_0 -log
libgen.log system.mss
Staging source files.
Running DRCs.
Running generate.
Running post_generate.
Running include - 'make -s include "COMPILER=mb-gcc" "ARCHIVER=mb-ar"
"COMPILER_FLAGS=-mlittle-endian -mno-xl-soft-mul -mxl-barrel-shift
-mxl-pattern-compare -mcpu=v8.20.b  -O2 -c" "EXTRA_COMPILER_FLAGS=-g"'.
ERROR:EDK:368 -  make failed for target "include"
ERROR:EDK:3418 - Error(s) while running make.
make: *** [microblaze_0/lib/libxil.a] Error 2
make: Target `all' not remade because of errors.
 But I still can't make much heads/tails out of it.
same issue for me. Seems due to a problem with the PATH variable. I used this solution http://www.xilinx.com/support/answers/43293.htm and it worked fine for me.
Antonello
Antonello
Voyager
Voyager
Antonello,
That appears to be it, you are a genius (I am embarrassed to admit how many hours I spent working on this)!  I had the same Git\bin in my path and as soon as I took it out and rebooted the machine, it seemed happy.  I would have thought that windows would have grabbed from the beginning of the path list first, but I guess not.
Is there some sort of workaround that you know of, because I have to use Git for this project, so it seems like I am probably going to have to add/remove from the path every time I want to compile or do anything with Git.  I wonder if there is a way to have the SDK kick off a custom path for its instantiation...
at the end I discovered that the cause of the issue is the file called sh.exe in C:\Program Files (x86)\Git\bin. Removing only this file and not the path, the bsp compilation works fine.
Antonello
Voyager
Voyager
Hmmm, I sort of had to take the opposite approach.  I removed the directory from my path (leaving sh.exe alone) and SDK works fine and Git appears to as well.  But if I do the opposite (rename sh.exe and leave the path in place), Git complains that it can't find sh.exe.
Not sure why the first works, but I guess I will have to go down that path in order to have Xilinx and Git play nice in Win7.
It was the same path & problem for me too. Thanks Anteonello! You saved me a great deal of time and frustration!
I know this is an older thread, but what path variable are you guys talking about? a windows enviromental variable??
I am having the same issue but I am a little embaresed to admit i dont know what path variable everyone is refering too..
If anyone can help me out I would apprciate it.
Voyager
Voyager
Right, there was a windows environment variable pointing to that directory.  Once I got rid of that directory (leaving all the other directories alone), it seemed to work then.
Which sh.exe is the Xilinx tool supposed to be using?  There doesn't seem to be one in EDK\gnuwin\bin, which is where I would expect it to me.  In my case, it is picking up sh.exe from my PARI install, which provokes this same issue.  I don't think the correct solution is to have no other sh.exe's in path, but rather for the xilinx paths to correctly point to an sh.exe (since they are first in the PATH, if this were the case, everything would work).  So, where is the sh.exe that Xilinx provides for use, that somehow gets used when there is no sh.exe in the path?
You probably saved me hours of frustration. BTW. We are now three years later. I am using 2015.2 and the problem still exists
Hugo
The forum kindly logged me out when writing my own post, so to summarize again:
  • Removing C:\Program Files (x86)\Git\bin indeed works, but I actually need this, so not very good solution for me.
  • There is no sh.exe in my C:\Xilinx folder at all. But adding C:\Xilinx\SDK\2015.2\gnuwin\bin and C:\Xilinx\SDK\2015.2\gnu\microblaze\nt\bin to PATH so maybe it will use that instead of the git one doesn't help. However adding those will allow you to run the command that instructs make to use the Windows shell instead of looking for an sh.exe so this will work even without removing the git path from PATH (see: http://stackoverflow.com/a/24066533/220230). Does anybody know a way to make the SDK pass such command line arguments to make? I couldn't find a way to do it.
  • The makefile could also be edited so the Windows shell is used (see: http://superuser.com/a/401808/47254), but if the makefile is auto-generated then any change to it will immediately wiped out...
I get the same issue and solved it thanks to Antonello (
I had the same issue and I could not remove Git from the PATH because I needed it there. I ended up finding this solution, and it may be good enough for some of you:
Instead of removing C:\Program Files (x86)\Git\bin from the PATH, change it to C:\Program Files (x86)\Git\cmd.
I've hit this issue again and it seems that I have to also remove TortoiseGit from my PATH environment variable:
C:\Program Files\TortoiseGit\bin
I have an SDK workspace with multiple apps and BSPs, and strangely, when I have TortoiseGit or Git in the PATH, some apps/BSPs build while others don't. For the ones that don't build, I get the error:
Jeff
